baseboard heat ???
  • baseboard heat ???
    I am helping a buddy troubleshoot his baseboard heat problem,he has an 8' and a 4' regulated by a seperate stat there is a white rogers device to them it is a 24A01/24A05 slimline level temp
    he has disconnected it and i have no wiring digram, I am a bit confused
    I know it steps down voltage for the stat but it has a couple of bimetas that activate a micro sitch, anybody know the proper way to wire this and maby expain what it does besides the transformer part???????
    thanx kevin k
    Re: baseboard heat ???
    chevy. search "white-rodgers 24a01 installation instructions". here you are and there you go. breid..............
      That is an electric heat thermostat relay. It does basically what you think.
      It has a set of contacts controlled by a self powered low voltage control, the thermostat.
      These are very common around here. The relays are typically placed at the electrical panel.
        Like Breid said, here is a link: http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
        Check out the first hit.
          thanx kevin k
          thanx for replies very helpful and I thank you guy's
          kwk
