Help: Repurpose Ceiling Fan wiring
  • Help: Repurpose Ceiling Fan wiring
    Need some help on this project (just a DIY'er). We have a ceiling fan that is running on 14/3 wire (1 switch for fan and 1 switch for fan light). I want to remove the ceiling fan and install 2 recessed lights and install 1 electrical outlet in the ceiling that can be turned on/off by a switch.
    Can this be accomplished with the existing 14/3 wire running to the existing fan?
    Thanks
    Re: Help: Repurpose Ceiling Fan wiring
    Yes
      Thanks
      Purely out of curiousity, what do you want a switched receptacle in the ceiling for?
        This is for friend who wants to mount a projector to the ceiling.
          That sounds like a project to really sink your teeth into. Your plan should work just fine.
