General 350 table saw-hook up
  • General 350 table saw-hook up
    I am wiring my new saw-5 hp, 1 ph.
    I am OK from panel to recepatacle and plug on power cord.
    However, the switch box on the saw has no apparent place to connect the cable. The line into the switch is black, white and ground (No issue with the ground). The issue I have is that now that I have all the wires to the saw, the box contains a whole bunch of electronics, but no place to hook up?
    Help if you can-please.
    Thanks
    Gib
    Re: General 350 table saw-hook up
    Please hire a professional electrician.
      How about the Specs off of the motor. The nameplate information. We can't help you if you do not at least provide the most basic of information.
      The nameplate contains everything required to connect the motor to the power source, in most cases.
      Licensed Electrician
