How deep
  • How deep
    presently, my detached garage gets its power via 10/3 UF from my home's main panel to a sub panel in the garage. the uf was buried 2' below grade and the original project was overseen and filed by a licensed master electrician in New York. a construction project will occupy most of the area the present 10/3 is in . i want to abandon the original 10/3 UF and rerun the line using plastic conduit with THHN as the conductor. can anyone quote the chapter and verse of the NEC that mandates the depth the conduit must be buried? thanks.
    Re: How deep
    NY Resi Code Table E3703.1 or NEC T300.5
    18" deep in almost any residential application.
      Re: How deep
      u can bury thhn in conduit?
        Re: How deep
        Pretty much all new THHN is also rated THWN.
          Re: How deep
          wouldn't fly in S.F., Heat build up.
            Re: How deep
            You do not understand. THHN is THWN look on the jacket.
            Licensed Electrician
              Re: How deep
              Care to explain this one?
                Re: How deep
                Happy too ! I just re read the 1st post. My mistake,I thought He was re using the original UF
                in conduit!
                  Re: How deep
                  LOL! No problem.
                    Re: How deep
                    Every once in a while,I see some Carpenter has Run romex in an Elec, conduit. UGHH!
                    Usually in a garage.
