blown out outlet (?)
    Re: blown out outlet (?)
    new update; I checked all the outlets and switches, lights for all loose connections, nicks in wire and there were none. the outlet that is good on top and 30 volts on the bottom is indeed a light switch activated outlet. that explains why 1/2 of it is good. I didnt check the interior and exterior porch light fixtures. they work fine so I figured the connections there should be good. am I wrong to assume this, dont they dead end there? so once again Im at a dead end. any other thoughts. this seems crazy. Glenn
      i'm also an licensed electrician. here is what i would do if i were you. i would hire a licensed electrician. imagine that. having to pay. breid................
        now what good is that here. I thought this forum was to help people figure things out. which usually with everyones help usually happens. if you dont try you never learn.
