Grounding a sub panel
  • Grounding a sub panel
    I'm looking to add a sub panel in my garage which is detached & about 50' away from the house.
    I know the ground & neutral need to be isolated in the sub panel, but do I need to run a separate equipment ground (green wire) back to the main house panel also? or can I install a ground rod at the garage & run the sub panel ground to that?
    Re: Grounding a sub panel
    Ask the local inspector what he wants. You can get varying answers. Sometimes it's run three wires and put in separate grounding for the garage. Sometimes it's run 4 wires with no separate grounding. Sometimes it's both.
      If you are under the 2008 code, then you need both, a ground wire back to the main panel and a ground rod at the garage!
        My 35 Lb. Makita Jack Hammer Loves to run ground rods in fast !
