Booster cables
  • Booster cables
    I`m going to make myself a set of booster cables and i`m not sure of the wire size to go with?
    I have a 750 cold cranking amps battery and i want my cables to be 30' feet long.
    Not sure if I need #1 or 2 or even 2 ot wire? I was thinking of buying some of that stranded welding cable??
    Thoughts?
    Thanks in advance fellas!
    Re: Booster cables
    the bigger you can afford the better they will be, your dealing with 12 volts and voltage drop is fast if your pulling 150 to 200 amps, I would suggest the welding cable as well, or equivalent,
    amp chart for welding cable, but remember the voltage on a welder is higher than a car battery, http://www.generalcable.com/NR/rdonl...5_SVT_Weld.pdf
    or
    http://gencable.com/index.shtml?cables/weld.htm
    check this voltage drop calculator it has 12 volt calculations,
    http://www.powerstream.com/Wire_Size.htm
      Re: Booster cables
      Get a couple pieces of old welding lead and put some clamps on them and you should be set.
        Re: Booster cables
        Wow some great info here guys!
        thx for your expertise!
