120v vs 240v breakers
  • 120v vs 240v breakers
    hey there!
    i am planning on installing an electric floor heating mat. i ran a little software telling me that i will be needing 240 to feed this sucker.
    now, i do have spare room in the load center for 6 breakers and i have 1 spare breaker (not installed).
    the requirements for the mat is 15A 240v. my spare breaker is rated 15A 120/240v. how do i get 240v out of a 120/240v breaker?
    do i have to put 2 x 15A breakers in the panel, the load going to one and the neutral to the other breaker (like a beefy range 30A breaker) or do i simply put 1 breaker, neutral red to the neutral bar and the black load to the breaker?
    thanks!
    Re: 120v vs 240v breakers
    Originally posted by HornyPotter View Post
    hey there!
    thanks!
    From what I just read, you better call an electrician!
      What he said!!
        Neither!
        a 2 pole 15A 120/240v breaker does the job!
        thanks to all for reading!
        cheers!
          YIKES!...someone must have posted an answer on another website...and off he goes.....
            I wonder how he hooked up the wires?
              kid
              who cares. breid..............
                people of little faith... red to breaker slug, black to the other slug of the breaker. no white.
                how did i find out? cracked open the the load center, checked other 240v breakers, mimic what i saw and bingo... 240v!
                saw the answer on another site? nah... did not bother going to any other site... such a good crowd here.
                i wish you all a nice jolt of 240v!
                back to you in the studio
                  They're running with scissors out there. It's scary.
                    I thought you only had one space available? If that's true and you installed a twin breaker (Murray MP1515 or equivalent), then you only have 110V. In order to get 220V, you need each pole to come from a separate phase and with a twin breaker, both are fed by the same phase....
                    Ideal Plumbing
                      What better way to learn electrical work. Simply copy what's already there.
