Yet another sub-panel question?
  • Yet another sub-panel question?
    In the midst of adding a new kitchen to an 1800's home here. The service has been upgraded to 200 amp at some point in the past 5-10 yrs but, as there is a mix of new and old wiring, space is limited. It seemed easier to install a sub-panel adjacent to the main for the new ktchn ccts.
    Now , I expected to see a lug-type sub, but instead it is a 100 amp main breaker type connected to the load center through a 50 amp dbl pole.
    Since this was signed off, it's obviously permitted but I can't understand: is it 50 or 100 amps and why the redundancy?
    Re: Yet another sub-panel question?
    Current is limited by the 50A breaker in the main panel. Sometimes it is easier to find a larger main panel especially when shopping at home depot instead of a good supply store. The 100A breaker on the 'sub panel' has no real function.
      Couldn't have said it better.
        Thank you for your replies. Clearly the 100 amp breaker is redundant; though my wording was perhaps awkward , I was wondering why a 50 amp fed sub panel would require, essentially, a 100 amp off switch.
        The answer in this locale is: 100 amp rated panel are preferred not only for ease of availability but as the minimum rating for an inside install.
        Also, the locality prefers a way to switch off the entire sub w/ out accessing main panel.
        Now, this next may deserve it's own thread but- at some point down the road I will put up a garage/barn for the same customers. The idea of another sub-panel doesn't seem a good one. Today the discussion turned to installation of a pass-thru panel w/ one meter providing 2-200amp main panels. Any thought/opinions here?
          This is not true at all. If the sub-panel is within the same structure as the main then it does NOT require a main disconnect or even a local one.
          If your AHJ's are requiring this then they are pulling this requirement from their butts.
          A residential 320/400A, single meter, two-200A panel service is quite common these days.
            Well, whether from his butt or no, the main breaker sub is what he got. It's a rural area here & until recently a hand drawn sketch would suffice as a "blueprint" in one township.
            It's funny though, last spring the building insp was requiring the use of 2x12 rafters on a 10/12 pitch in a non-occupied, no utilities, 12x12 garden shed. Seemed a little overkill.
              You're in NY. You should find a new inspector that has a clue.
              This is not at all uncommon for smaller jobs.
                The 100A might have been the choice based on availability of amperage and space combos. Maybe the 100A had the 12/24 spaces required or whatever the case may be and nothing small had enough space. A 60A may have only had 4 spaces...
                Ideal Plumbing
