Can I install GFCI in old two-plug receptical box?
  • Can I install GFCI in old two-plug receptical box?
    Just moved a used clothes washer down the narrow stairs into an elderly man's basement.
    (He has been washing his clothes in his kitchen sink.)
    1940s? house. Conduit is to metal outlet box on cement basement wall.
    Will GFCI work without a ground?
    I'm planning to run a gronnd wire but must find it in my garage mess.
    Thank you.
    Robert
    Re: Can I install GFCI in old two-plug receptical box?
    Yes gfci will work.
    Is the whole house wired in conduit or is the conduit just a sleeve for protection coming down exposed basement wall?
    You can pigtail a ground wire to the metal box to the recept if its all in conduit.
    Huck
      And if the GFCI is not grounded, it must be labeled "No Equipment Ground"
        Originally posted by huckster4 View Post
        Yes gfci will work.
        Huck
        Huck, your answer is confusing me.
        Are you saying: Yes a gfci will work without ground?
        Or
        Are you saying: Yes a gfci will work if you do this.........?
        I work in a lot of older homes and often need to use a 2 prong adapter in ungrounded outlets to plug in my gfi extension cord. I've often wondered if it would still work without a ground.
          YES, a GFI will work with no grounding means present.
            Or
            Gene, like Speedy said, yes it will work with no ground.Sorry for the misunderstanding.I just think safety is a major concern when dealing with electricity . Having a grounded outlet is safer,which is why I offered ways to ground the outlet.
            Thanks Huck
              Thanks Huck
              Am I right in thinking that a ground is basically a back up neutral?
                No sir you are not. Ground is a noncurrent carrying conductor.
                Neutral is and does carry current.hope this helps.
                Huck
                  Huck
                  Exactly.
                  The ONLY current a ground is supposed to carry is fault current.
                  Most lay people and handyman types think since they are connected to the same place in the main panel that they serve the same or similar purposes outside the panel. This is absolutely NOT true.
                  It's what happens to them, where they go, and what they are connected to outside the panel that matters.
                    one reason to have the circuit grounded is in the event that the gfci does not function. i had seen more than one gfci where the fault part no longer functioned but the recp part still did. in other words acted like a regular recp. breid...............
