Attic fans
  • Attic fans
    Is it okay to put plugs on attic fans and then plug them into a switched outlet?
    Re: Attic fans
    I don't know if its okay...but mine is not like that...and all the ones I have seen are not like that....they are all hardwired...I know that don't help much.....
    Derek
      Re: Attic fans
      If you are talking about "Attic Fans" as in either gable vent or roof mounted, the ones I have are hardwired in and have their own thermostat and humistat (sp) that come on automatically according to the settings I set. Therefore there is no need to have them on a switched line. I think it would be a real pain to have to remember to turn them on and off all the time. Just my 2ยข.
        Re: Attic fans
        He may be talking about a whole house ventilating fan mounted in the ceiling joist bays below the attic in which case a switched receptacle could be used.
          Re: Attic fans
          We had to replace our roof due to hail and the existing roof vent fans were trashed. I thought that I might save some attic time by pre wiring with plugs and then just plug the replacements into the existing outlet that's up there.
          Turns out I just hardwired them today when the roofers put the new ones on the deck. Wow it was hot up there. Thanks for the responses.
            Re: Attic fans
            I have an electric attic fan.
            I have it wired to an on/off switch down in the utility room.
            This way, I can shut the fan off completely during the winter
            I can turn it on during the summer and rely upon the thermostat
            to turn it on/off as needed.
            I believe my fan is hard wired into a box. then the wire is routed to the on/off switch.
            Having a switched outlet up in the attic is another option.
            Cactus Man
              Re: Attic fans
              The only reason I would have it switched or connected with a plug/outlet (and I would) is to make it easier for replacement. It's just safer for the electrician or whoever is replacing it to be able to completely disconnect power.
              Ideal Plumbing
                Re: Attic fans
                It's perfectly compliant and some might argue the disconnect (switch) is required if no receptacle is provided.
                Licensed Electrician
