Almost Embarrassed...
  • Almost Embarrassed...
    I'm almost embarrassed to ask about this, but I'm sure I've asked dumber questions.
    I was working on an existing CPVC line today. Every time I touched it, I got a little shock. I'm thinking I'm losing my mind or maybe muscle fatigue that feels a little like a shock the first couple of times.
    The third time I felt it, (Like a dumb monkey, takes three times to maybe learn...) I got out my meter.
    Now, I'm not very good at electrical troubleshooting as to where to touch what and to put my mind into where the ground or neutral is going if you know what I mean.
    Anyway, I touch one of the probes to the CPVC pipe and the other just jammed into the ground. Got a reading as high as 9 volts.
    Why would I be getting anything on CPVC?
    Thanks for all input.
    Re: Almost Embarrassed...
    was this on a well by chance?
    Derek
      No, it was not on a well.
        I have only encountered that one time in the city and it was from cable tv wire ran thru attic and down behind the tub and was rubbing on the water pipes until it exposed the wires against the metal riser to the bath then just conducted thru the water to the grounding on the water system....
        Derek
          There are a couple dozen possibilities. I bet the voltage is higher from the pipe to a known good ground, like a cold water supply pipe or a nearby junction box. Nine volts is pretty difficult to feel except if you put your tongue across both + and - terminals of a nine volt battery. That is if the place was wired correctly in the first place. Is the jumper wire from one side of the water meter to the other in place and tightly connected? I wouldn't waste your time on it past notifying the homeowner or business owner of the problem and advising them to get an electrician out there pronto.
            Pretty sure what you're experiencing is static buildup from water rushing through the pipes. Static electricity can collect on the outside of CPVC even though plastic is an insulator. Dust collection systems (especially in wood shops) suffer greatly from this.
              but how does electricy flow on a plastic pipe. CPVC
              I could understand a possible static shock, but a stedy flow of power, as many plastics will develop a static charge if dust is moving through them, (use PVC on a wood dust collection system or use a PVC pipe to blow cellulose insulation,
              Scope:
              Dielectric Strength is a measure of the electrical strength of a material as an insulator. Dielectric strength is defined as the maximum voltage required to produce a dielectric breakdown through the material and is expressed as Volts per unit thickness. The higher the dielectric strength of a material the better its quality as an insulator.
              Dielectric Strength ASTM D 149 IEC 80243
              Dielectric Strength (V/mil) ASTM D149 PVC 1,413 CPVC 1,250
              Abbott Plastics: Materials - PVC & CPVC
              another chart on plastics for comparison, http://www.curbellplastics.com/techn...h-plastics.pdf
                Ah, but is AC or DC current...
                  Don't take this wrong JC, but did you even think about which to check for
                  first...AC or DC?; or did it not even cross your mind and you just checked for AC?
                    I don't take it wrong at ALL. I honestly expected everyone to say I was just crazy. I only checked for AC. It never crossed my mind to check for DC.
                    Thanks.
                      Well normally I would think as probably most would, that AC would be all you had to worry about, not because DC can't kill or injure you but AC is more common. But generally speaking IIRC if using your meter to look for the presence of voltage you would set it for Ac first then if finding no AC switch to DC and check for a DC component. You could actually have both (AC riding on top of DC) but not likely in the places you would be.
                      Do I remember that right Killavolt or anyone else?
                        are you telling us jc that you're ac dc
                          I have no idea what that means out West. In the South the only AC/DC we know about involves electricity or Bon Scott.
                            To save some Googling.
                            RIP Bonnie.
                              I use Fluke meters and they automatically switch over to the current/voltage you are trying to measure. I am an electrician and I immediately jumped on the AC voltage bandwagon. Never assume anything, I suppose...
