Question
  • Question
    I'm buying a new construction home, and right after I move in, we are having either granite or quartz tops installed on counter AND backsplash. We also are going to have under-cabinet lighting installed as well, and I have a questions.
    The outlets on the wall where the backsplash is going, don't those outlets have to be moved outward for the stone backsplash? If they have to be moved outward, will it be a pain in the butt for the electrician?
    Does a separate switch need to be installed for the lights?
    I have to accept the house the way it is as far as standard electric installation practices are concerned.
    Why don't I get them to install the granite and the lights from the start? Because they don't and won't offer what we want, so we have to wait until we move in.
    Also...do you electricians recommend a certain type of under-cabinet lighting? I don't want those lights that are long and square...that's not the look I want.
    Yes I will be hiring an Electrician...cause I don't mess with electric when Plumbing or Heating is not involved. I want the installation to look right, as I'm extremely anal about things.
    Re: Question
    I'm not an electrician but I worked at a Holiday Inn Express this week...so to extend an outlet out to accept the backsplash is easy. There are special adapters for just that type of thing that make the box deeper. As for lightinig? The sky is almost the limit any more. All kinds of options out there.
      Re: Question
      Rings on the boxes.
      Light rope..Many different configurations as far as intensity,shade.
        Re: Question
        Ok you 2...let me see your Electrician license.
          Re: Question
          Outlet bars mounted on the bottom of the cabinets, eliminate the outlets in the backsplash all together... Only way to go with full granite backsplashes!
            Re: Question
            Es Aqui Mio
              Re: Question
              Es Aqui Mio
              Where were You the last SINK OH OH, DEMIOO ???????
                Re: Question CONGRATULATIONS TO YOU AND MOM !!!!
                I wire for FIRE Under My Ca. G.C. Lic. HA HA ,PLUMB FOR LEAKS TOO.
                you definitely want a switch wired in first , and wiring for lights ,maybe each side of window! And go to a lighting supply and ask what units DON'T HUMM !! Did Steve Perry's kitchen [Journey] about 25 years ago . ist ones in HUMMED. Lesson learned! He was very nice !
                  Re: Question
                  Es Aqui Mio
                  Now that's funny. I don't care who you are
                    Re: Question
                    Rings will work, but I like to install adjustable boxes Adjustable Zip Boxes if you can get them to use these instead of whatever non-adjustable ones they use. I would get with your electrician to see what he would like to make his job easier after they finish.
                      Re: Question
                      Es Aqui Mio
                      Expiro en 2007
                        Re: Question
                        You need box extensions to bring the box out to within .25" of the finish surface.
                        The under cabinet lights can not be added to the existing counter top receptacles, those receptacles are SABC's (small appliance branch circuits) and can not have anything else on them. It would be easy to branch of the existing lighting circuit and add the switches during the rough in phase.
                          Re: Question
                          Make damn sure they don't just leave the minimum amount of wire for the next guy to work with or it will be an extra PITA............ I like the idea of the receptacles in the bottom of the cabs. Any one have pictures of that so I have an idea how it was executed?
                            Re: Question
                            Since I don't have the luxury of this builder conforming to my wishes, how hard will it be for the electrician to run his wire for the switch to operate these lights?
                              Re: Question
                              re pushout for boxes requiered because of extra depth from backsplash; spark rings; avail at yr local hd.
                              wire length issues... im no electrician either but here they are supposed to reqire 6" in the box, which is ample to the point of sillyness. Should be plenty to meet the extra 1/2" of depth you need for backsplash.
