rigid conduit pipe threader
  • rigid conduit pipe threader
    is there any difference in the dies for RMC compared to gas pipe that plumbers use?
    i know PVC plumbing pipe is OD but is black iron gas pipe measured ID like RMC?
    Re: rigid conduit pipe threader
    There is a straight thread and a tapered thread but I believe both currently use a tapered thread. I believe the fittings for electrical are straight while pipe fittings are tapered.
      ......just to add, plumbing pipe is measured by it's ID (nominal).
        havent made a cut yet but the dye i got from my plumber fits over RMC easily
          there is NO difference same dies work
            Their both N.P.T. - National Pipe Thread. There will be a slight taper on the end of the thread to assist in starting a fitting, but you can actually make a running thread (although illegal By NEC that you can thread a coupling all the way thru. By RMC I believe you mean Rigid Metal Conduit. The normal terminology in the trade is GRC, for Galvanized Metal Conduit.
