1/2" romex clamps
  • 1/2" romex clamps
    Gentleman , How many pieces of 12-2 w /G romex can you put through one 1/2" romex clamp. Thank You
    Re: 1/2" romex clamps
    Usually two. Sometimes, but rarely three.
    It should say on the package or the company web site.
      Thank You for the reply I usually put 2 in there and not set the screws to tight but I did not know what the new NEC says. Thanx Richard
        2 only if UL listed for 2.
          What if they are "UL listed" for three?
          Such as the Arlington 841?
            Then you can use 3. I generally only use 1.
              Wow. Really?
              Seems like a terrible waste of space to me.
                Wow. Really?
                Yes. Generally, I exceed the box fill of the box before I run too many cables in. And for panelboards, there's always more than enough knockouts and I can always drill one.
                  This is my point. If the panel is even close to full I find I run out of KO's quickly. And drilling is not always an option, especially on top.
                    For 12-2, I would use only 2 per connector....14-2, I usually use 2 also, but 3 if I find that I'm running out of KOs or connectors.
                    Ideal Plumbing
