wiring
  • wiring
    Am I able to use 14-2 wire for a microwave and one additional outlet?
    Re: wiring
    You might be able to get away with it for the micro alone, but NOT with an additional receptacle. Kitchen receptacles are required to be on 20A circuits.
      Re: wiring
      Maybe the microwave is in the living room....
        Re: wiring
        Kitchen Two 20 amp circuits on new work here + dedicated circuits
          Re: wiring
          Maybe the toilet is in the KITCHEN! It's Georgia after all.
            Re: wiring
            Why run the risk of burning dinner when nature calls?
              Re: wiring
              What kind of microwave, and what kind of power are we talking about? Will it work? Yes for a while. Will you have problems if you try using multiple appliances at once on that circuit? Most certainly yes. 12-2 is not much more expensive than 14-2, especially for a small job like this, run it in 12 and never have to worry about it.
              My microwave is considered small at 800 Watts, but it has a built in convection oven. When I am running it at full tilt boogie, it will and has in the past tripped the circuit breaker when I had the ol hot pan on the same plug.
                Re: wiring
                Only some one from the left coast would think that.
                It's outside!
                  Re: wiring
                  Many house type trailers have dual interior lights. They work on 120vac and 12vdc. I'm thinking perhaps something going on with that maybe? Also, when reading voltage with a voltmeter there is VERY LITTLE current being drawn so you can easily get a reading with either a bad connection on the plus or ground side. Once you add a good load a bad connection will show its face. Try this, one one interior light check the voltage at the same time another light is turned on and see if you have a massive Vdrop on the line.
