Ground Wire Connection Point
  • Ground Wire Connection Point
    Is there a reason why some #6 ground wires I see are connected to the main neutral in the meter base, while others I see are ran from the ground rod to the top of the riser mast and bonded to the main neutral at the weather head? Does it make a difference as to which connection point is used? Just curious.
    Re: Ground Wire Connection Point
    Installer preference.
    ©Mike Holt
      AWESOME PIC!!! Thanks for the info Sir Speedy!!!
