Well pump breaker tripped, but still have water
  • Well pump breaker tripped, but still have water
    Hello. The breaker is tripped and will not go back on. Is this an electrical problem or well pump problem? I have no idea in regards to this.
    Re: Well pump breaker tripped, but still have water
    That depends, the pump motor could be locked up or there could be a short in the wiring. The test would be to remove the supply line to the well pump starter box and see if the breaker resets. if so there is a problem with the pump motor or the starter. You still have water because there may still be pressure in the tank for a while.
      So do we remove the metal cap of well pump which is in backyard? Please bear with me as I'm an absolute novice with breaker boxes/home repair.
        What kind of pump do you have?
        In the well (submersible)?
        Above the ground (Jet)
        Do you have a "starter" box? You may not. Majority don't in my experience.
        You need an electrical meter to troubleshoot.
        The breaker buzzing or kicking could be the box/capacitor but more likely the well pump.
        Being a novice as you say I would advise to call a licensed plumber or well contractor. Should be able to have you running soon.
          I agree, not knowing any more than you do, it would be advisable to call a Well/Pump person.
            And it could just be a bad breaker.
            26+6=1
              I agree, (best advice)
                It seems to trip when I run the shower in the morning. Once reset, it usually doesn't trip again until the next time I use the shower. The problem was intermittent but has become increasingly consistent. Could it have to do with water level in the well(in kind of a dry spell)? Could it be the breaker?
                "Ruhrpumpen.com" Leading Manufacturer Of High Quality Centrifugal Pump
                  it could be the breaker or little pieces of SPAM jammed in your centrifugal pump
                    Spammer trying out the forum boot em!
                    Seattle Drain Service
