Need help installing a sub panel for multiple A/C units
  • Need help installing a sub panel for multiple A/C units
    My project consist of adding a sub-pannel to feed 3 A/C units that are located on my roof. I would also like to connect a security flood lamp to it and future expansion for another 2 A/C.
    I have space in the breaker box to add a few more breakers. The main outside is a 200a. The run is about 85ft long. The existing conduit is of 1in.
    What size (amp breakers), wiring gauge should I use?
    The loads will be 5 A/Cs (split units) The A/C's are 8amps, 11amps and 14amps. Future A/C's would be of 11amps each.
    So;
    8, 11, 14, 11, 11 for all five A/Cs
    I am a handyman and are confortable with doing this job.
    Thanks in advance.
    Re: Need help installing a sub panel for multiple A/C units
    Too many variables to give a simple answer. This is not a handyman job. I strongly recommend getting a licensed electrician to do the work. Especially if you are not the owner.
    If you are insistent on doing the work, Start by reading NEC art 230 and 440
      This is for my house!
        Your project will require a building permit.
        The building inspector requires a licensed electrician to do the work.
        With that said you may be able to negotiate the grunt work required and thus
        keep the coast of the licensed electrician low.
        For example I had an electrical project.
        I dug the ditch, I installed the conduit, I pulled the wire. The electrician inspected my work and said it's fine.
        He did the actual wire connections in the panel [Which obviously I could have done] and then put his seal on the work.
        The inspector passed everything as well as my home owner's insurance!
        If you do this yourself without the proper permits and inspections....you will introduce
        some serious potential problems....
        your home owner's insurance will not address any electrical claims you make or any claims
        they find related to the illegal electrical work! In fact they may just outright cancel your policy!
        Can you afford that in lieu of saving a few bucks doing this project yourself?
        I am also a homeowner and quite skilled, however there are projects that you must recognize the bigger picture
        and call in licensed professionals...There is a reason they have licenses! There is a reason for building permits!
        Cactus Man
          In most locations you as a home owner can do the wiring but it is to be inspected some times two inspections, a rough in and a final, and permitted before the start of the project, you will just have to check with your local building department, if you can do the work your self or not, regarless you should or need to wire to the NEC.
            Your house has a flat roof and needs five separate AC units?
              He must be one hell of a handyman.
                Bob Vila?
                  Guys , I am in Puerto Rico and construction here is a little different than the states. The roof is also made out of concrete.
                  I am a Veteran and yes I been called Magiver!
                  I can do many things!
                  Can someone help me with the wire gauge and breakers?
                  The existing conduit is 1in so I was thinking 3 #6, ground #8 with a 60amps breaker???
                    "Mans got to know his limitations" Clint Eastwood
                      Do you really want the wiring in your house to be based off of some random persons advise you got off the internet? I don't think,insurance covers that, I'd recommend you hire a electrition and do as much of the work yourself as he permits.
                        I agree. Hire a pro. Its a shame when innocent people have their houses burn down because some hack thinks he knows what he is doing
                          Being a veteran doesn't give you any special privileges.
                            Thanks for Your service ! Now go hire an electrician, Vet.
                              Contact an electrician.
