please help me in my muffle furnace
  • please help me in my muffle furnace
    I will build a muffle furnace for treatment it's range to 1200 C
    my problems is for inside electric wire what type I uses
    Re: please help me in my muffle furnace
    heating wire is usually ni-chrome. supply wire should be standard 600 degree insulation. if your supply wire is becoming too hot, then there is something wrong with the design of the unit.
      what I means not heating wire
      I means the wire which is produce electricity to the heating element
      thank you my brother
        we need to know the ampacity of the unit and the voltage suppled.
          here is a manual for a commercial made unit, and on page 37 of the manual it looks like they could be using a copper web that is clipped on to the ceramic heating element,
          http://www.nist.gov/ncnr/upload/E133thermolyne.pdf
          http://www.chida.info/furnace/CD1700x-e.pdf some pictures of the elements, and working on them,
          do a google search
          muffle furnace manual - Google Search
          do some looking and see what you can find.
          I have never seen one or used one, I even had to look up what a muffle furnace was,
          Is there one in a lab you can go look at and copy the design,
            zollerforge.com Simple propane forge. EZ to make N operate ! Good luck
              probably MG wire or a similar high temp wire with glass insulation. Why not call the service # and ask what they use?
              BTW,be sure to use gloves when handling this wire
