Help Finding Blubs Page Title Module
    Re: Help Finding Blubs
    Looks like this one - 4.6" tall, 4 pin
    CF13DD/E/835/ECO/BL/1 20643 Sylvania
    edit: here it is, cheaper
    20643 Sylvania DULUX 13 Watt Double Tube Compact Fluorescent Bulb with 4-pin base, 3500K color temperature, 82 CRI, ECOLOGIC for use on magnetic ballast - CF13DD/E/835/ECO/1
      Wow, good find.....except......double WOW, at the price! Second link is 5.2" tall, no good.
      At lease now I have a little something to expand my search and maybe find one about three times cheaper than the one you found.
      Again, good work and Thanks.
      Ron
        Ron
        oops. i did a part number/model search and just 'assumed'. apparently the model number didnt change with the specification change. wouldnt hurt to contact them to see if it's a typo though.
          any of these work?
          13 Watt 4 Pin GX24q-1 CFL Compact Fluorescents | 1000Bulbs.com
          some are 4.3"
          click also on the little 'see all' link. there should be 8
            That's pretty much what I've been trying. With that high $$ one you found I figured that if I use that # I could locate some more, wrong. It's truly amazing how many variations there are within that number search, with most, if not all, are 5.2" tall.
            If I can't find any others, that leaves the one you found and for 4 bulbs, it would be close to $75.00, including S/H. That's going to be a hard pill to swallow if forced to go that route.
            Ron
              As you said that you have made countless effort so now it depends on you that you want to continue with your search or can replace it???
                How about this one? http://www.amazon.co.uk/Osram-Dulux-Plus-Very-White/dp/B000YETCQU
                Length is 4.17”
                • #23
                  Originally posted by lesliemorris85 View Post
                  Yes, I'm still searching and appreciate those still looking also. The length they list is 9cm, which by my conversion is 3.54". The problem with this one is that they list it as 230V.
                  Osram Part Number 447001
                  Height 48 millimetres
                  Length 9 centimetres
                  Width 48 millimetres
                  Weight 60 grams
                  Voltage 230 volts
                  Specific Uses General Use
                  Plus, I'm not very good at money conversion in figuring out what the Price: £7.95 (£13.25 / 100 g) really is
                  The Search continues...............
                  Ron
                  • #24
                    Okay... Just keep on searching.
                    • #25
                      has anyone checked bulb direct!
                      thats the one i use
                      coffee hell gimme booze!!!
