Drain cleaning putting on a spark show
  • Drain cleaning putting on a spark show
    Did a drain cleaning and camera job today for a new forum member with a plugged up sewer. the pipe was a combination of abs, orangebird and clay. all non metalic pipe.
    had my k-60 plugged into an outlet in the garage that was suppose to be a gfi protected outlet piggybacked from anoter outlet along with my k-60 having a gfi line cord.
    what i noticed was when i was running my cable in and out of my k-60, i was seeing an arcing between the cable and machine. i've never seen that before. used my meter and found some power when hooking my lead to my machine frame and ground. it was less than .01 volts, but it still registered. the water service is copper, but there was a grounding bonding wire disconnected. seems like the ground rod was removed, but the water line is copper into the ground.
    i eventually swapped outlets and seems like the arcing was gone. glad i didn't short out my k-60, seesnake or myself
    i don't ever remember seeing this before.
    ps. i did clear the line and and got him up and running.
    Re: Drain cleaning putting on a spark show
    Thanks for the reminder Rick . I will pick up one of these today ! Grainger item #5yl47 in line 15 amp, 120 volt Inline GFCI $66.00 . I'LL find it cheaper elsewhere . We should all use these daily on customers homes !
      did you ever figure what was electrifying the water in the drain?
        Loose neutrals, also a dangerous situation, can cause similar effects. Or maybe static electricity built up from the metal snake on the plastic pipe? If the ground was an insulator you'd see small sparks at the machine.
          Wow for time in the trades ,You are one sharp DUDE ! Gramps is impressed
            I think the issue was with the outlet and the water was just the path to ground. Never tripped my gfi on the machine. And the outlet I was plugged into was suppose to be on a gfi piggyback outlet.
            When I changed to a different outlet, the problem, arcing went away.
            Rick.
              Thank you sir
                Rick.
                I'm no electrician for sure. The switching of the outlet may have provided a better path for ground/neutral than the other circuit. I saw this in my cousin's house. Using one GFCI receptacle with a drill cause the lights to get brighter in that area of the house. Other areas were unaffected. Switching the receptacle, as you did, made the problem 'disappear'. His GFCI never tripped either. I'm not sure why not, I don't know the workings of the GFCI receptacles/cord adapters or how reliable they are. I'm used to the breaker panel installed units that protect everything downstream.
                Perhaps an electrician can chime in on the oddities of electrical flow and MTBF of GFCI units?
                  Improperly wired outlet. Really bad for your camera if you plug into one of these
                    TRC GFCI OUTLET TESTER TECH RESEARCH - Cable Protection Systems - 8XEY7|30090-012 - Grainger Industrial Supply
                    This what I use to check outlets but truthfully don't do it on a regular basis. Will do for the camera work now. Josh, my toolbox monitor has a fuse in it....does the new cameras have one and would the fuse protect anything in Rick's situation?
                      if there was a boot leg ground or reversed polarity boot leg ground one of the three light wire testers may not show it, and I do not know if a ground fault would show it either,
                      GFCI work
                      Ground-Fault Circuit Interrupters (GFCIs):
                      will dropping a hair dryer in a sink trip a GFCI (not necessarly)
                      the GFCI will only trip if the power going in and coming back through the white and black wires is imbalanced,
                      it could be possible for power (from a nother source) could be flowing on the ground and not effect the line coming in,
                      now if that power from the line is leaking to ground then a proper working GFCI will trip, but as show above is there is no place for it to leak it will not trip,
                        Thanks Rick N Josh. This is a wake up call for all with cameras ! When You Plug into a homeowners receptacle , "You are rolling the dice with a valuable Piece of equipment ! His brother in Law ,Pluto ,May Have wired it 240 Volts last Sat. !!!!
                        Get an in lineGFCI AND USE IT !! Gramps
                          That's what batteries are for, love mine
                            Cheap way to check is a plug-in GFCI tester. About 8 bucks, they have 3 lights on it and will show reverse polarity, open ground, open neutral, etc. I use it to double check co-apprentices outlets
                              Not according to the YouTube video that bhd linked. Even the $300. Meter pretty much failed.
                              Rick.
