My 16 gal. S.s. Ridgid shop vac stopped working
  • My 16 gal. S.s. Ridgid shop vac stopped working
    What is Your Guess, Please ? Switch ! Is there an internal fuse, circuit breaker ? Tanks Tool
    Re: My 16 gal. S.s. Ridgid shop vac stopped working
    There is usually an internal fuse inside the windings someplace. It's for an overheat condition but can fail because it's a POS. Other causes can be loose connections, bad plug, or bad switch. The easiest to test is the switch - use an ohm meter for continuity.
