AFCI Started failing
  • AFCI Started failing
    My house is about 2 years old now. No issues with electrical to this point. Just yesterday one of my AFCIs popped. Went down in the basement and switched it back on. No big deal.
    Went home for lunch and found that it had thrown again. Circuit is definitely not overlaoded. Has a few outlets, a 3 way switch down the the basement stairs with a light at the top and bottom and a single pole switched light.
    Do AFCIs go bad? Could this be from a light bulb going bad?
    I will likely switch the AFCI out with another one in my box tonight to see if that's the cause. Wondering how often these actually fail and what could cause and issue after all this time.
    BTW.. no new nails or screws in the wall. Nothing that would explain new arching.
    Thanks,
    Josh
    Re: AFCI Started failing
    Afci Breakers don't like Motors ,vacuums.smoke detectors,hate power strips,. Please take a picture of all Your breakers. What brand panel? They are a nuisance at best ! Spread them out on each buss bar, not all on one. Do a search on Electricians talk for More info. The 2014 NEC Mandates more of these and folks will learn to HATE them. Especially when You come back from vacation and Your freezer and Refridge are full of ROTTEN MEAT ! RANT OVER
      In this case they actually had a nice save. Worked my way down to isolating one light and found a definite issue. Cheap light fixture that the insulation had pulled back from over time. once question though. Whats up with the yellow moisture. is that just from the arching? definitely not leaking from anywhere.
        Looks like the wire casing melted inside fiberglass sheathing. I've seen this happen in fixtures that usually have a much larger watt bulb than the fixture is rated for.
          Josh, I see rust on the metal fixture. What's above it? Possibly a plumbing leak getting things wet? Time to play detective.
          Rick.
            Good work
              I checked thoroughly above the fixture. Its actually chain hung and zero sign of moisture above. Nowhere near plumbing of any sort. Could the moisture be from arching?
              Also... could the insulation getting fried cause the moisture. Everything was very brittle around the place it was arching. Wondering if the arching pulled the oils out of the plastic and rubber.
              I will check again to see if there is any possibility of the roof leaking and dripping down through but again. it seems very unlikely for the water to get to where it was. A bit of a mystery.
              BTW... The builders installed 100W bulbs in the fixture which the fixture is rated to.
                Doesn't arcing create ozone? That would explain the rust, but not the moisture?
                Rick.
                  With today's houses and the over the top requirements of making the houses air tight, you end up with moisture problems at any penetrations. If the light box was not sealed correctly and being on the ceiling of an insulated area, you can get condensation. Simply it looks like the fixture over heated for some reason or another.
                    Originally posted by toolaholic View Post
                    Afci 2014 NEC Mandates more of these and folks will learn to HATE them. Especially when You come back from vacation and Your freezer and Refridge are full of ROTTEN MEAT ! RANT OVER
                    Not mandated n kitchens so this is usually not an issue.
                      How about back up garage Refrig., and Freezer full of food ?
                        Garage should be GFI not arc fault
                          This was mentioned on Electrician talk .I don't have the 2014 NEC Just 2011 one
                            If that's a concern they do sell gfci receptacles that will give you an audible alarm when they trip.
                            Its worth noting that afci circuits also have (a lesser level) gfci protection already built into them.
                            I was told (by a hvac guy) its not a good idea to put a fridge in a garage because the colder ambient will screw with the defrost function. Then again... many say they never have a problem
                              depends upon how the fridge controls the defrost function. electronic timers have no problem, temperature sensors sometimes have problems.
