Outdoor fan, switch and receptacles for under patio roof
  • Outdoor fan, switch and receptacles for under patio roof
    Power from the panel will go first into a GFI outlet. Then I want to add another outlet that will be powered from the LOAD side of the GFI. I am a little confused on how to take power to the switch.
    In the diagrams below is one way more preferred over the other as far as the load side of the GFI giving power to the other receptacle and switch(1) or should the power for the switch be grabbed with the line side of the GFI(2)?
    Re: Outdoor fan, switch and receptacles for under patio roof
    There will be two unused terminals on the non-GFCI (but still protected) second receptacle. Use those instead of pigtailing your wires to feed the switch/fan. Don't forget your ground wires. I assume you left them out of your drawing for clarity.
      Electrically speaking, is This way(#3) really any different than diagram #1. And yes I left the grounds out to not clutter diagram.
        Apparently you did not like the answers you got over at DIYChatroom. As you were told there, schematic 2 will not work as you are using the GFCI neutral with the line side hot. This will cause an unbalance and trip the GFCI.
        Outdoor Fan, Switch And Receptacles - Electrical - DIY Chatroom - DIY Home Improvement Forum
        If you want that configuration, run 2 separate neutrals and 2 separate hots. Run the load side of the GFCI to the second receptacle and use the other neutral and hot from the GFCI line side to power the switch and light and/or fan.
          Has nothing to do with liking an answer. I dont see an issue with having other opinions seeing as if the post on DIY appeared over.
          Thanks for suggesting.
            Putting the fan on the un-used terminals of the 2nd receptacle may be allowed but then the load of the fan
            and its light fixture, however slight, is added to whatever load is plugged into the duplex receptacle, and
            this is all in turn running through the GFCI receptacle with its own load.
            Now the GFI is not looking for a circuit overload I know, it watches for an imbalance in the circuit
            of ~5mA or more at which point it trips. It serves a different purpose than a circuit breaker.
            But I am not an electrician so put no faith in what I am saying, you are better off going with what Killavolt says.
            Killavolt, is it common to mix ceiling lights and/or fans with receptacles on the same circuit in a room, or
            would you consider this a special case. Does the fan need to be on a GFI circuit because it is outside on
            a covered porch. Why not put a GFI breaker in and be done with it. If the GFI receptacle has not been bought yet
            there is not much difference in the price is there, a few dollars maybe but would seem to be a better setup.
              You can look for all the opinions you want, schematic 2 will not work as it will trip the GFCI
                Either diagram is fine.
                On another site someone said:
                Originally posted by hj View Post
                I, personally, do not like to see stationary motors wired through a GFCI because of false tripping, so I would use the second one.
                So how is one to know who to believe seeing as though I have no way of knowing anyone's credentials.
                  Look at the 'occupation' in the upper right corner of the poster's message. 'Electrician' is a good one to look for.
                    And because someone types the letters that spell electrician in the occupation field, that absolutely 100% means the person is an electrician? Do the moderators at this site ask for state licenses when a person puts a professional trade as an occupation and verify said license? I dont buy it.
                    I appreciate the comments on all forums but an just trying to gain confirmation. No harm no foul.
                      The problem with a a GFCI breaker is if it trips you have to go all the way back to the panel to reset it. Either will work but the GFCI receptacle is more convenient. What she really should do is pigtail the feed coming in from the panel with two wires, one to feed the fan/light and one to feed the GFCI and the other receptacle downstream. That will take care of any imbalance issues as you were correct in pointing out.
                        Isnt this exactly what diagram 2 shows? The feed is pigtailed with 2 wires, one is feeding the switch and the other is feeding the GFI.
                          Killavolt.
                          The problem with schematic 2 is that it uses a non GFC hot, with a neutral off the load side of the GFCI. This will trip the GFCI.
                          BTW, I lived in Southington off Jude Lane from 1967 to 1998 (originally from Berlin). Have lived in South Carolina for the last 15.
                            Based on those comments you can't get a confirmation here. If you have issues believing what is written by an 'electrician' on a DIY forum you have no business asking for help on said forum. You REALLY need to go to your local union electricians or hire an advertised, licensed electrician to help you.
                              ANy thoughts on if this arrangement would function or would it cause the GFI to trip? The duplex, which is shown at ceiling level, will have both halves switch controlled.
                              Thanks
                              This is also posted on several other forums in case that is an issue for some. Dont know why it would be but putting it out there.
