Use of PVC box adaptor
    Re: Use of PVC box adaptor
    Yes, you'r probably right but there should Not be "room to slide" as the photo shows
      Originally posted by rosem637 View Post
      SO is this how to use? Seems like there is still some sliding of the adaptor body because the coupling does not sit all the way against the box sidewall. Unless when glue and primer is applied the, the coupling will slide further onto the adaptor?
      that is the correct way to use them but they need to be glued and pushed in tight enough so there is no sliding.
      these are similar to the rigid condiut bushing (These screw into the coupling)
      coffee hell gimme booze!!!
