curious
  • curious
    does anyone know what the voltage or amperage exiting a ballast to the bulbs is? Have always been curious but no one I have asked seemed to now. thanks ken
    Re: curious
    typical fluorescent ballasts have an output voltage around 600 volts or more with a low current.
    but neon lights can easily exceed 1000 volts
    kind of am interesting thing to think about if you are handling a lit coors neon light
    coffee hell gimme booze!!!
      Re: curious
      Arent the ballasts variable voltage? They have a high voltage at light-off then drop down to 26 or so once lit? I thought I read that someplace.
        Re: curious
        correct once the plasma arc is started in the bulb the voltage drops off.
        but the amount of drop is dependent on the length of the bulb
        fluorescent bulbs use low pressure mercury vapor and phosphor coating inside the tube.
        while neon type bulbs use gases such as neon, argon, or krypton
        the high voltage arc ionizes the gases exciting the atoms and the energy the give off forms the different colored light
        here are some wikis on them
        Neon sign - Wikipedia, the free encyclopedia
        Fluorescent lamp - Wikipedia, the free encyclopedia
        hope this helps
          Re: curious
          WOW! I learned a lot, thanks fellows
