Electrical running under main beam.
  • Electrical running under main beam.
    I have a prefab house and I’m curious if the electrical wires running under the main beam/header that runs the whole length of the house are ok? This was done by an electrician so I’m assuming it’s ok. The reason I am asking is because I’m finishing the basement and starting to run wire myself. I would prefer doing it the same way, so I don’t have to drill through 6 boards and 2 pieces of 1/2” osb. This will only be done in the unfinished storage room.
    Not pretty but it is not a code violation.
