535 for pvc coated rigid
  • 535 for pvc coated rigid
    Will a 535 thread 2" pvc coated rigid? (will the jaws open enough and clamp. Or is the the OD to large for the machine to clamp)
    Thanks in advance
    You mean like 2" Robroy? I doubt it, that stuff is pretty thick.
    I'm gonna guess the OD is about 2.5" It would be close if it did fit.
    The manual for the 535 just says 2" nominal for max capacity.
    It doesn't give the actual maximum capacity but that would
    depend also on the die used.
    Here's a cut sheet for PLASTI-BOND REDH2OT.
    • offcominout
      offcominout commented
      Editing a comment
      Fantastic...TY for the time and response!
    • Bob D.
      Bob D. commented
      Editing a comment
      You're welcome.
      But even if it did fit the jaws will chew into the coating severely and probably ruin it.
