Only half of plug works
  • Only half of plug works
    Plugs that worked good but every since new heat pump was wired into fuse box I have power at plug but no neutral . Anything plugged in does not work
    I am no electrician .... that being said my guess is that the outlet circuit white neutral wire at the main box is loose on the neutral bar creating a open circuit at the receptacle's .
      Thankyou I’ll do a check at box to see if it’s loose
        Yes. You're right. That may be the main reason.
