Essex Gas Valve
  • Essex Gas Valve
    I have an Essex Gas valve M/N SX242NOA. It is coroded and can't be repaired. I am having trouble locating one. Can anyone help me?
    Re: Essex Gas Valve
    Is this for a gas furnace? Try to google it. If nothing comes up, check w/ honeywell and find a gas valve with the same specs.
      Re: Essex Gas Valve
      Take a few good pics of it post them here along with the specs of gas valve and rating plate of equipment and we can find the right match for you.
        Re: Essex Gas Valve
        OK.Thank you so much for replying. I have taken a few pics of the Gas Valve. It is from a ducted heating system. Hope you can help with finding one that matches. I went to my local HVAC dealer and he sold me a Honeywell V800 A 1179. He said it would do, however the wiring on it is wrong, even though it looks similar. I have googled for hours trying to find one. That is how I stumbled across this site. Hope you guys can help me.
          Re: Essex Gas Valve
          WOW! that is one gunked up gas valve
          Whatever you do DON'T post any pictures of the appliance that thing came off of because I will tell you to junk it.
          I STRONGLY suggest you get a professional to replace it and evaluate your system.
          The gas valve you need is listed below
          HTML Code:
          click_Me_Now!
            Re: Essex Gas Valve
            Thank you Plumbers Crack. Believe it or not, the rest of the system is in perfect order. Thats why i want to replace the valve. I suspect the cover was left off the unit for a while before I moved in.
            Thanks again.
