Iced over condenser!?
  • Iced over condenser!?
    Going to check a call tomorrow about an ac unit. I thought the evap was icing over but after talking with the customer's husband, I found out the condenser was icing up within 2 hours. It's straight ac, haven't seen it yet so the details are sketchy. Any preliminary thoughts?
    Re: Iced over condenser!?
    2 most common are, low air flow (dirty filter or coil blocked return grill). or low charge.
      I know this for icing up evaporator, but a condenser? Find out today more details and will keep you guys posted.
        Is this straight A/C or a Heat pump?
          Straight AC as far as I know. Just a thought, if it was a heat pump with a very low charge, could the low pressure cause the reversing valve to switch to the heating mode causing the outside coil to ice up?
            My guess is, it is a heat pump and they didnt know it. The h/o probably just installed their own el-cheapo stat and wired it up wrong. Either that, or their description of what is happening, sucks.
              Fixed the unit today, this is what I found:
              1. It was a Trane heat pump with fixed orifice.
              2. Low charge- my pressures were 25/80!!! Superheat was 65. The factory charge was 4lb 6oz. I put 3lb 6oz in before everything came to normal.
              3. Outdoor unit was dirty from grass being mowed around it.
              4. Condensate was plugged up.
              5. They were using the top efficencey filter causing the indoor coil to ice up.
              6. Schrader valve was leaking from the true suction schrader valve. Didn't have a cap on the end. I replaced all three just to make sure.
              Thanks for all the help guys. And no I did not charge 150-300 dollars for the refrigerent.
                Well done,
                Also, glad you did not screw over the homeowner for the refridgerant.
                I am sure when they have problems in the future, you will be the first to call.
                Regards,
                  Wanted to add; this was for a church, they paid 4000 for a new evaporator and the hack never wanted to come back to fix it right. What a shame. To fix all that took me 1 1/2 hrs. I hope that 4000 was worth it to him when he goes to the "hot spot". I'm not a religous man but you never know.
                    4K for a new "evaporator", thats steep, I dont care what part of the country you are in.
                    Glad you got it fixed up for them.
                    regards,
                      Well $430 of that $4000 was for 4.6 pounds of R-22. The other $3570 was probably just the cost of the evaporator. I'm guessing he did the job for free, so he should be plenty safe when the afterlife calls.
                        No arguments here, Some things are just plain "WRONG" no matter how you spin it!
                        Rest east tonight, you deserve it.
                        REgards,
                          Gear
                          You did well and will be remembered for not ripping them off. Someday you'll be rewarded.
