roof saftey help
    Re: roof saftey help
    Try these http://www.ultimateridgehook.com/
      They make a thing called a ladder hook. Basically it's a steel hook that attches to your extension ladder and hooks over the peak of the roof. It even has a wheel on the back side so you can slide the ladder up and over.
      The big question though is what in hell are you doing on the roof? Never heard of Kozy Collars?
        what the hell is a cozy collar. im up on roofs because everyjob i have to pull a cimney liner down onto the mech room. never heard of the ladder hook. allot of the sighn company's around here use a simmalar idea without the wheel. i tried and it didnt work that well. most roofs i go up on are multi level. you end up dragging 3 big ladders up top, most too long so you have a huge overhang.
        how is it that so many answers are in the instructions
          How about renting a lift truck
            i have actually done that and it obviously works well. the situations often are ones where the houses are tight together and they have front garages, and no back alleys. so its not often that a lift will reach the chimney
