heater inducer motor not running
  • #31
    Re: heater inducer motor not running
    If the CS is stuck closed, it needs to be replaced. That would make a little bit of sense as to why you are able to effectively 'push start' the inducer. It makes more sense that you are able to unplug one of the CS wires from the PCB and get the inducer to start when reattaching the wire. What doesnt make sense is your fault code says the CS circuit is open.
    Now that you've troubleshooted this, do yourself a favor and get a pro out to fix it. This unit needs to have a once over done by a pro with a trained eye.
    • #32
      Especially for SAFETY reasons
      • #33
        Have to buy the whole motor since they don't sell the CS switch alone. Took 45 minutes to install and now works like a champ. Thank you all for the help.
