Humidifiers On Newly Installed Furnace
  • Humidifiers On Newly Installed Furnace
    When installing the humidifier on a new heating system does the humidifier get mounted before the heating element... or should it run through the humdifier after the air is heated? It has occured to me that if it is heated before it passes throught the heating process the humidity would be removed from the newly heated air. ???? thanks
    Re: Humidifiers On Newly Installed Furnace
    the air should be heated before it hits the humifdifier , it will aid in the humidity in the house.
    how is it that so many answers are in the instructions
      thanks, I didn't do the install....the instructions say NOTHING...
      Any differing opinions???
      again, thanks
        again, thanks
        the humidifier goes in the supply duct after the air handler
