Connection ridgid ducting to exhaust fan
  • Connection ridgid ducting to exhaust fan
    I'm installing an exhaust fan and using rigid 4" ducting. The ducting has a tapered end, which I assumed goes into the ducting attached to the outside vent, but I don't know how to secure the non-tapered end to the fan itself, as both the ducting and the connection on the fan are 4" exactly, I can't fit one inside the other. How is this supposed to be done, is there a coupler of some kind that I need?
    Re: Connection ridgid ducting to exhaust fan
    You need a crimping tool or a band coupling.
      Thanks for the reply. What type of crimping tool would be required? Do you just pinch a bunch of grooves into the end of the venting?
        Your 4" pipe should fit on the outside of the piece on the fan. Either you have some pipe that is built on the small side of the spec, or you arent trying hard enough. I assume the connector on the fan is plastic?
        Andy
          It is indeed plastic, and I've been trying to shove the damn thing on there all day. This is what I've got: http://www.homedepot.com/webapp/wcs/...00003+10054001 It comes flat and you curve it around and lock it together.
            Also, what's the loose round plastic ring (collar) for on the vent? Or more specifically, what do I do with it? http://www.homedepot.com/webapp/wcs/...00003+10054001
              Well I picked up a "vent extender" which is a short piece that is crimped on both ends, so I'm guessing I can just shove that in there and duct tape the whole mess up.
                Pitch it in the garbage is what I do with them.
                The 4" aluminum pipe is typically smaller than 4" galvanized steel. Get yourself some 4" galvanized. The big end will fit the fan. The small end will need crimped a little to fit the 4" deflecto. Or save yourself some trouble and flex it.
                Andy
                  Yeah I'd be way into using flex venting except I'm working in the ceiling of the first floor of a 2-story house, no attic to work in, so rigid is the only way I can figure to reach from the fan to the wall. I haven't seen galvanized venting, but I could check for it tomorrow.
                    Funny how Home Depot usually figures into these aggravations. You can do it.. we can provide the sub standard crap from China
                      Your HD links do not work, at least for me. But if you are talking about a white nylon collar that comes with a 4" dryer vent, it is simply to trim the inside of the rough hole you cut through the wall for the 4" pipe.
                        The ducting you describe where it comes semi-flat, and you push the long edges together to form the pipe...that is usually galvanized steel. If in fact you have some aluminum stuff, that would be too flimsy. Trade it in on the steel.
