Steam Piping
    Re: Steam Piping
    no 3" wye
    I checked. dull black o rings need to be swapped in for low pressure steam applications.
    Greg
      Re: Steam Piping
      Originally posted by plumbworker View Post
      did the mantinence guy tell you if it is the return or not is it graded..? i don't see why you couldn't use a tee..? i repaired a few copper steam leaks in the past it will a ***** to drain to make solder joints.. is this in the city..?
      No, and I didn't think to ask as I was half way planning on doing the entire repair in propress, but with no 3" wye I was back to thinking about cxc swett.
      Oakland/Berkeley border
      Greg
        Re: Steam Piping
        Originally posted by glkearns View Post
        My part to the job (if I take it) would be repairing the failed joints. The facilities maintenance guy knows the ins and outs of the system, but can't solder the 3". I openly admitted to the client that I had no experience with steam systems, his response was that he knows the system and just needs someone that can solder large diameter copper.
        I have been contemplating punting on the job since I walked it (Friday) because of the lack of knowledge of the system.
        Greg
        Don't run from this job. You are only replacing joints. Ask questions I will help if you need it. Steam is tricky but you can do it if you replace whats there if it is currently working without kinks.
        First off you let the customer know that copper piping is really not the correct pipe for a steam system. Put that in your contract. Secondly if the wye fitting is of iron pipe or cast leave it where it is and just adapt to it with the proper adapters. There is a reason that it is a wye and not a tee. It may be a counter-flow system where the steam and condensate use the same pipe but flow in different directions.
        Check out Dan Holohans site www.heatinghelp.com Dan is the steam guru and is the best out there. Dont give up on this job.
          Re: Steam Piping
          And do not use pro-press please.
            Re: Steam Piping
            A picture would be nice, however you can replace the wye with a tee fitting. The only reason to use a wye on steam (and it's usually a c.i. fitting) would be for a sediment trap with the branch down and plugged or capped. they probably just used what was on the truck at the time. Remember that steam leaves the boiler under pressure, and moves throughout the piping in the same way that air would.
            Fitting direction has little effect.
              Re: Steam Piping
              If I go back I will take a few pic's. I think I want to quiz the maint. guy and see if he is all he's cracked up to be before I agree to it and buy the whole damn problem.
              Greg
                Re: Steam Piping
                Allowing a Plumber work on steam piping is like putting lipstick on a pig. Call a licensed fitter....
                • #23
                  Re: Steam Piping
                  Maybe in Alaska Sara.
                  Here it's part of plumbing, plumbing license required to install boilers.
                  By the way...yer kinda hot...pig or no pig, ya got my vote.
                  • #24
                    Re: Steam Piping
                    a licensed fitter?
                    • #25
                      Re: Steam Piping
                      don't know about no stream fitters license. We don't have em here. Don't even have to be a licensed plumber to work on steam ( or heat for that matter) Not many steam guys around anymore. I started off my career installing, servicing and piping high pressure process boilers.
                      • #26
                        Re: Steam Piping
                        what pressure is the system running? what is the steam used for?
                        • #27
                          Re: Steam Piping
                          I'm a plumber and approved to do steamfitting, in its our curriculum...Let me ask you Sarah, do you wear lipstick?
                          West Trail Mechanical Ltd
                          www.westtrailmechanical.ca
                          • #28
                            Re: Steam Piping
                            Greg
                            If you do end up doing this in copper, I would SilFos, not solder... I've done jobs that were only atmospheric pressure steam lines, but had to be silver soldered
                            • #29
                              Re: Steam Piping
                              15psi for heat (radiators)
                              All existing is regular soft solder.
                              Greg
                              • #30
                                Re: Steam Piping
                                Greg
                                Are you sure it's running on 15 psi or is that the max.
