Boiler Work
  • Boiler Work
    As most of you know, I manage the Pressing Tools at RIDGID. I'm always hearing that folks want 1-1/4" Jaws to do boiler work with. Can someone explain to me why this is an important size? What would the additional 1-1/4" jaw allow you to do that you can't do now? Inquiring minds want to know!
    Thanks for your help!
    Re: Boiler Work
    1-1/4" is a very common size of the tappings on a hot water boiler. Also 1-1/2" & 2" is also common but 1-1/4 is most of the sizes I come across on residential boilers.
      Re: Boiler Work
      Exactly what MP said, the inlet/outlet taps on most residential boilers are 1-1/4"...we wind up making the steel manifolds the same diameter then branch off in 3/4" to adapt to the more expensive copper.
        Re: Boiler Work
        Same here
          Re: Boiler Work
          But why the need for 1-1/4" copper? We used to run to the manifld in iron , then off of there we would go to copper, all of it was 3/4" sweat.
            Re: Boiler Work
            What if its only one zone and the main(s) are bigger then 3/4 as many if not most of replacement boilers are?
              Re: Boiler Work
              Still Iron, I was taught to run Iron to the FlowChecks or Cirulators after that copper. I just thought that there already was 1-1/4" jaws for Pro-Press
                Re: Boiler Work
                I agree. I always manifold with iron if there is more then 1 zone. If there is only one zone though I will just use copper.
                  Re: Boiler Work
                  I was beginning to think something was wrong with me I catch so much grief from everyone at work because I pipe every boiler with iron. Now I see there are others just like me.
                  The new swivel jaws for 1-1/4" ProPress that fit on the 100B might just get me to buy a kit
                  I like the idea of ProPress on boiler replacements. Beats waiting an hour for the mains to stop dripping so you can solder.
                    Re: Boiler Work
                    GREAT info guys! Thanks. Indeed we do have the 1-1/4" rings right now that will do the job, but we do not yet have an 1-1/4" ProPress Jaw. Perhaps in time for Christmas...? I'm sure they'll make great stocking stuffers!
                      Re: Boiler Work
                      Copper manifolds are only necessary on aluminum or steel exchangers..found on high end condensing boilers.
                      With the current price on those boilers, I just don't see an overwhelming demand for the mainstream.
