Clamp meters for HVAC
  • Clamp meters for HVAC
    I have recently purchased a clamp meter which is Ideal 702.(It is my fiirst clamp meter in my life). It is ok but I realized that this meter does not have amp DC function.
    I am a entry level gas techician and plumber so I do not have much technical work.
    For hvac tech. what kind of clamp meter and functions are required?
    Thanks.
    Re: Clamp meters for HVAC
    Ive been using my Fieldpiece SC66 for 10 years. It does everything you will need including temperature. I use a Fluke 80pk-8 Type K thermocouple pipe clamp for checking superheat and subcooling. Sometime in the next couple years I will upgrade to the SC76 which is autoranging.
    Andy
      Andy
      I use the same thing.
        How about TPI-270?
        Have you ever use this one?
        My coworker just bought one.
        Thanks.
          For a the best HVAC meter go with a Fluke 116.
          I use a simple amp clamp as a seperate tool
          It will do everything you need and is less than $175
