Hybrid Systems
  • Hybrid Systems
    What are the advantages of Hybrid HVAC systems? Becoming more popular in this area and was curious about them.
    Re: Hybrid Systems
    First off - what IS a hybrid HVAC system out of curiousity?
      Re: Hybrid Systems
      I'm assuming you mean combo wood/pellet burner, gas or oil backup.
        Re: Hybrid Systems
        Here, my hackjob competitors have adopted the "Hybrid" term to describe a dual fuel system. (air to air heat pump with gas backup) Their commercials talk about these huge savings but fail to mention the customer 'might' recoup the cost difference by the time the unit needs replacing.
        The only dual fuel system I have installed is at my parents house which is 8 hours south and considerably warmer.
        Andy
          Re: Hybrid Systems
          Do you mean Hydro air systems, where water from a boiler goes though the heat exchanger? If so the advantage is that you can have hot water heat and AC too without having to run both naseboard and ductwork. I would imagine that they cost about the same I never did any AC nor can I tell you what the heat exchangers run. Possibly someone else can though!
            Re: Hybrid Systems
            Andy
            Ruudy nailed it I think. I've seen this going in on a couple of residential jobs and installers act like their great. Maybe marketers like attaching the word "Hybrid" to everything.
            Thanks.
              Re: Hybrid Systems
              I had a duel fuel system installed and love it. I have a 2 story house with 2 heatpumps and 2 gas furnaces as backups. I only had gas before. The price wasn't much different than going with straight electric or with an a/c unit and gas furnace, but my utility bills are lower than before, both winter and summer.
                Re: Hybrid Systems
                Hi JC,
                We are coupling hybrid heat pumps with solar Pv. Makes all the sense in the world in our area... essentially solar powered heat & AC
                spodelee
                Until lions have their own storytellers, stories of the hunt shall always glorify the hunter
