Chilled water system - pump head
  • Chilled water system - pump head
    While calculating the pump head in a closed loop chilled water system, we need to determine the total friction losses that a pump is supposed to overcome in the piping loop.For this purpose only supply line upto the coil (AHU / FCU etc) should be taken in account or return line from coil back to the pump should also be considered.Or in other words equivalent length of the critical path comprises of both supply and return piping length or only length of the supply line upto the coil.Thanks
    Re: Chilled water system - pump head
    Is that on a massive hospital ?
      This is Mechanical Engineering 101
      If you don't know the answer to this you are in the wrong profession
