Draining hydronic baseboard heat?
  • Draining hydronic baseboard heat?
    I am a carpenter by trade and need to move 21' feet of baseboard heat to install a custom set of built ins. I woud like to know how to drain the system the safest/effective way and how to re-start system, any suggestions? it is an oil-fired boiler.
    Re: Draining hydronic baseboard heat?
    this is not a simple task.
    are there plans to re-install it?
    Vince
      to drain it shut off boiler ,close valves ,cut pipe and suck up water with shop vac .
      call a heating co to move pipe and re fill system and start boiler
        Carpenters should cut wood not pipe. Let the heating guy cut, drain and reconnect for you. If this was a warm weather season you could take the chance, but during the winter you don't need the grief!
