Plastic Duct Clamp v Gear Clamp v Bridge Clamp for 8" Flex Return
  • Plastic Duct Clamp v Gear Clamp v Bridge Clamp for 8" Flex Return
    Are the Plastic Duct Clamps adequate and are the Gear Clamps and Bridge Clamps overkill for an 8" return flex duct? Where is the best place to buy these products, Lowe's, Depot or a HVAC supplier?
    Re: Plastic Duct Clamp v Gear Clamp v Bridge Clamp for 8" Flex Return
    I use 36" plastic zip ties ( can get smaller ones for an 8" line) and they work great... I zip the inner plastic liner then zip again over the outer insulation jacket.
    It helps to have a zip tie puller / cutter as well if you go this route, tho one I have is made by Matco and works great
    I stay away from HD and Lowes... Your local HVAC supplier will have exactly what you need.
    Okie
      OK, Bill thanks for the tips!
