lennox cg80tb
  • lennox cg80tb
    hey guys...i have a lennox cg80tb propaine split system
    in my attic. i want to replace the heat exchanger gas with elec
    do any yall know what unit i would replace it with?
    and..i know i will have to tear the thing apart. but is the exchanger a "unit" ...slide in /slide out?
    I like it like that !
    and, It's like that now!!!!!!!!!!!!
    Re: lennox cg80tb
    You may consider leaving the LP exchanger in place and adding the Heatstrips aftermarket (premade plenum section with heatstrip mounting capability)
    Or if you are brave install the heat strip package directly into your metal plenum
      Re: lennox cg80tb
      +1
      Probably easiest to add a heat package to your discharge duct.
      Cheers
