Direct vent heater won't shut off
  • Direct vent heater won't shut off
    I have a
    perfection
    direct Vent Wall Heater that won't shut off. I installed a new thermostat that worked for 2 weeks, now the only way to shut off the heater is manoally turning it off. I switched thermostats and that did not correct it.
    It runs evenwith the thermostat disconnected. Any ideas anyone?
    Thanks
    reber
    Re: Direct vent heater won't shut off
    I appologize I read the problem real quick and assumed you are talking about a water heater please disregard this post.
      Disconnect the thermostat wires at the unit. If it shuts off, you have a cross-connection somewhere in the stat wire. If it continues to run call a reputable licensed heating contractor as this isnt something a homeowner should be tackling alone.
      Andy
