Would this work?
  • Would this work?
    i've been trying to come up with an idea for a fanless range hood vent.
    i made this drawing and would like some feed back.
    the distance from the hood to the vent termination would only be about 3 feet maximun.
    Vince
    Re: Would this work?
    You would not want the vent pipe to come into the stack (wind pipe) at a 90 degree angle. Lower the angle to get a venturi effect going which will help draw out through the vent and help prevent wind from blowing down your vent as well.
    Okie
      If I was going to try that I would leave the top pipe full size and then run the smaller up into it and a elbow and face it down wind, it should create a venture effect and suck on the smaller pipe.
      but I would think with the heat differential you have just a 3 or 4 inch pipe going up and out side would draw like chimney would, put a damper on it so one can shut it off when not using it,
        umm this is a vent for a range hood? you do know that these hoods have a powerd fan yes? and that by code you have to have a flapper on the hood vent to prevent any downdrafts and to keep the birds and squirls out right?
        take a peek at something like this: http://images.google.com/imgres?imgu...a%3DN%26um%3D1
        no need to over complicate this its prety streight forward let the powerd fan do all the pushing or id you like use a gravity vent:
        http://www.indiamart.com/airierindia...ntilators.html
          i've seen those wind turbines before. but those things don't last very long up here because of the wind.
          this would be for a cabin where the amount of power will be limited. off the grid as it were.
          i came up with the idea when i was cleaning a carburator for my ATV. but i'm thinking that i may have to modify the design a little.
          Vince
            Next the customer will complain about water noises from p-trap.
              Vince make it work like a wind vane so it is always pointed into the wind. Let the Horz. piece rotate and put a tail on the downstream side so it will keep it turned into the wind.
                LOL people will think hes got a Howitzer on the roof pointing at them LOL.
                Seriously if its a low power sitch then go with the gravity vent it'll catch the wind in whatever direction its blowing and you can get a good one these days you just have to look. OR (shhhhhh secrets being spilled) look up a resteraunt hood manufacturor and see if you can get a grav vent from them, All SS and shiney and made to last forever or untill the insurence fire
