Compress Shield?
  • Compress Shield?
    Compress Shield (compressor oil additive), best thing since sliced bread or snake oil?
    I'm thinking Slick 50 for a refer compressor...
    $15 bucks per ounce @ 1 ounce per ton is a bit high...
    I get nervous adding anything to a refer system ( I won't even use dye).
    Your thoughts?
    Okie
    Re: Compress Shield?
    Ya Im with you. I highly doubt there are very many compressors failing because of poor oil quality.
      I believe more compressors are damged because of not using a nitrogen purge and getting a good vacuum then the compressor oil
