Exhausts for clothes dryers
  • Exhausts for clothes dryers
    I looked a job today that had three industrial size clothes dryers.
    The brand was maytag and the hot air exhausts were near the bottom of the machines.
    The outlet is about 4"
    My question is can I join all three together or do I need to run each one out separately.
    Simon
    Re: Exhausts for clothes dryers
    dryers should all vent separately.
    the reason is because there is no check valve to keep the exhaust from 1 blowing into the others. plus you'll get condensation in them if they were common.
    even large commercial units all vent separately.
    make sure to use smooth bore metal pipe and an aluminum flex to connect it with. no plastic flex.
      Don't use screws to fasten the duct together. It'll snag the lint. I saw pvc pipe for the dryer vent in Africa and it worked great and has lasted for 4+ years. Contractors wrapped bare copper wire around the pipe and grounded it for static electricity.
        Commercial dryers can common vent.
        Your equipment manufacturer will list how they want it done.
        Most just use a simple barametric(weighted) damper at the outlet of each dryer.
        Here is a good basic read...
        http://www.geappliances.com/commerci...nting_spec.pdf
        Okie
          What is your equivalent of our mechanical code? You should be looking there for answers in addition to here on the forum where most of us are located in the USA.
          John Ruskin (1819 - 1900)
            Okie
            that's pretty cool.
            i've seen a drawing of something like that except it was used to vent gas HWH/HWT in an apartment block.
            my instructure said it's used a lot in EU.
            Vince
              I don't know that there is a mechanical code for this sort of work here.
              I have taken a " Phone a friend " approach and spoken with friends in HVAC and there suggestion is to run each one separately into a common dampener box with a removable filter, then out through louvre vent with vermin mesh.
              Simon
                Plastic pipe of any kind not allowed here...fire code.
                  I know back in North Carolina if the dryer vent ran under slab the mechanical contractors would run it in 4" PVC.
                  I also lived in an apartment once where the upstairs dryer was on a common vent with my dryer, i'd open my dryer door after they'd run theirs and find condensation all over the inside of the machine, really bothersome if there were clothes in there. I got to where i'd leave the door open between uses to keep it from smelling.
                    That's what's wrong with having a common vent.
                    I know it does not apply where you are but if you want to read the requirements here you can view the NJ MEchanical Code online here;
                    http://www2.iccsafe.org/states/newjersey/
                    See section 504 for clothes dryer venting. It discusses both residential and commercial installations (section 504.7) but for the most part throws you back to the manufacturers installation instructions in addition to requiring an exhaust fan that is interlocked to each dryer such that the fan will run whenever any of the connected dryers is running.
                    Last edited by Bob D.; 05-17-2009, 06:22 AM. Reason: Added link to Mech Code online.
