Pool Coil
  • Pool Coil
    Could one put coils in the corners of a "normal" sized pool to use as the heat removal/exchange from A/C? Heat the pool too if wanted in the right area?
    Beneficial? Energy savings? Just thinking again. Hope I don't hurt myself.
    Re: Pool Coil
    Yes would work
    I think using a water cooled condenser and using the pool as your supply and return source would be the best bet.
    This way there are no coils in the pool you are just taking a supply and return off of the pool pump or a small secondary pump.
    Okie
