Maytag IQ
  • Maytag IQ
    Has anyone had any experience with their A/C's and heat pumps? Their high SEER 22-24.5 and 12 yr parts and labor warr sounds attractive.
    Re: Maytag IQ
    A few thoughts...
    --24.5 SEER ( Ultra high SEER) is typically not available in anything bigger then 3 ton (36K BTU) in Maytags case 2 ton . If you go to a 4-5 ton system which is more the norm for a residental system you will see the SEER drop Bigtime.. .
    --Maytag 24.5 SEER @ 24,000 BTU is as good as they get. The more telling part of this is the fact that the EER on this system is still only 15
    --The really telling part of this is that any Maytag System above 3 Ton and claim 20+ SEER cant even qualify tor the Stimulus Tax rebate due to the low EER ( must be @ or above 14EER and above 16 SEER to qualify for the $1500)
    Looking at the numbers Maytag is trying to claim the highest SEER as a selling point but neglecting to tell you about the cruddy EER which is a better indicator of a systems worth IMO.
    12 year parts no problem you still pay the labor the numbers will work in my favor (not saying this is the case just being a pessimist)
    just my 2 cents
      2009/2010 Federal Energy Tax Credit Requirments
      Air Source Heat Pumps >= 8.5 HSPF, >= 15 SEER & >=12.5 EER for split systems
      I believe Maytag 12 yr warr covers parts and labor
        Re: Maytag IQ
        Just curious....who is the maker of Maytag equip? Fedders used to make the Maytag window and wall crap, and mercifully went by the wayside.
          Re: Maytag IQ
          Nordyne makes the equipment.
          Labor is NOT covered under the 12 Year Parts Warranty http://www.maytaghvac.com/MTHVACwarr.asp
          The bar for heat pump systems is set a bit lower but you still have the same problems as the straight A/C systems I mentioned in my last post...
          By chance do you have any of the AHRI numbers for the rebate qualifing heat pump systems, I can't find any
          Bill
            Re: Maytag IQ
            This might be what you're looking for:
            http://www.ahridirectory.org/ahridir...ages/home.aspx
              Re: Maytag IQ
              Bill,
              Thanks for reiterating the non-labor coverage of their 12 yr warr, which is a deal-breaker in my book.
                Re: Maytag IQ
                Thanks Killavolt, I use the AHRI site alot though I'm not the best at narrowing down my searchs..
                I'm just having problems finding a maytag heatpump system that qualifies for the big tax break / rebate.
